Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Problem with replaced Logic Board
I've replaced my MacBook Logic Board, but the screen is black. If I tilt the screen all the way down and shine a light on it, I can see the desktop. I guess this is a back-light failure? If anyone has a solution or a suggestion on how to proceed here, I'd be very grateful, since I would hate to have wasted the money I've spent on fixing my comp, and not being able to finish. Thanks for help!
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Hey, they say "Better late than never" :)
Anyways, I found enough time to play with my MacBook again and this time it works. I don't know where the problem was the first time, but everything's OK, except the DVD unit. I also upgraded the RAM to 4GB, and it works like a charm.
Just wanted to follow up on my previous post, thanks again for all the help!
por
Adicionar um comentário
1 resposta
Solução escolhida
Sounds to me like you have a bad inverter or bad inverter cable. Here's how I replace it: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
Is there a reason you replaced the logic board first?
You check my diagnostic hook it up to an external monitor.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Hi there, thanks for a quick response!
The reason why I replaced the Logic Board first is that the computer was dead Replacing logic board from E-bay another thing is, the MacBook doesn't recognize my DVD unit anymore, but I assume I must have not connected it back properly after putting it back together.
I guess I'll get a new inverter with the cable and try to replace them and post back how it went. Thanks again for help, talk to you soon!
por
Adicionar a sua resposta
tajvanc será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 372
