No brakes at all
Used car as normal following day really struggled to turn over once started could not take foot of accelerator or car cut out.
Put battery on charge put back on car started straight away makes a noise but have no brakes
Esta é uma boa pergunta?
Pontuação
0
When you push the brake pedal, you feel it's harder or smoother than the normal usage ?
por Vertinhol
Hi ,
What is the year and model of your vehicle?
Have you checked the brake master cylinder in the engine compartment to see if the brake fluid level is at the correct level?
What happens if you start the engine with your foot on the brake pedal and applying slight pressure, does the pedal sink down or not?
por jayeff
