Ir para o conteúdo principal
Televisions made by the Chinese multinational electronics company, TCL.
Replacement LCD panel for TCL 32S305?
Does anyone know where I can find a replacement LCD panel for a 32” TCL TV model #32S305?
Esta é uma boa pergunta?
Pontuação 4
6 comentários
Evidently TCL doesn't want anyone finding out where to get replacement parts, I usually use shopjimmy.com but even they don't have a screen replacement.
por
San po makabili ng panel screen tcl 32inches thanks
por
I find TLC LCD led32d2910d
por
Hi droped tv no broken screen but screen not visable
por
Mag Kano po ang LCD screen ang model nya ay LED32D2500 salamat po
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
@fkdiscovery
replacement panels are very difficult to come by. If you can find a replacement it is most likely more expensive than a replacement TV. You will have to do a search by the panel number. Remove the back of your TV and take a look at the back of the panel. You should find a sticker on it that will tell you the maker and the exact number of the panel. Use that number to do an online search.
Esta resposta foi útil?
Pontuação 7
5 comentários:
Thanks, oldturkey03. I took it apart, but there was no label on the back, I guess because of its a LED LCD display. I did, however, locate a label on the connected T-Con Board that gave me the display Model #ST3151A05-8. Apparently you are right about the price too. Paid $120 for TV, replacement LCD would cost $88 with min purchase of 4. Best deal after hours of surfing the web. Could not find just one for sale.
por
@fkdiscovery yes that is so common. It gets even worse with the larger panels. To bad that people have to abandon their TV's just because of broken LCD screens.
por
In my opinion it should be illegal not to supply parts for something that cost so much %#*@ money
por
Amen MissAnne!!
por
I most definitely agree.
por
Gear Up For Future Repairs
Adicionar a sua resposta
Dale Knight será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 43
Ao todo: 17,728
