Ir para o conteúdo principal
The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
I cannot find Keyboard replacement guide.
Not sure how to replace keyboard, since my keyboard not typing, if i buy a replacement, i will replace it. For this model all parts described but not for keyboard replacement. I have Chrome book 2 Toshiba , model: CB35-B3340
Get back, thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @gennady46
Here’s a link to a video that shows how to remove the palmrest assembly (which includes the keyboard) from a Toshiba Chromebook 2 CB35-B3330.
I realize that this is not exactly the same model number as your laptop but according to this website the keyboard is compatible with both the B3330 and the B3340 so perhaps the replacement procedure is the same.
This supplier was to show the keyboard compatibility between the two models and also to give you an idea of the cost of the part. There may be other suppliers online that suit you better. Just search for Toshiba Chromebook 2 CB35-B3340 keyboard to get results for suppliers.
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks so much, all the best!
por
Adicionar a sua resposta
Gennady Gurin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 323
