Ir para o conteúdo principal
The Acer Chromebook 11 was released in December 2015. It can be identified by its model name: CB3-131-C3KD.
LCD Screen compatibility concern
Will the LCD screen for the Acer Chromebook CB3-111 fit within the CB3-131?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @cgaviria ,
Whilst it may physically fit I'm not sure that it will work, but I may be wrong.
The CB3-111 has an Active Matrix TFT panel while the CB3-131 has an IPS panel and I don't know if the pin assignment from the motherboard to the panel will be the same.
Just a thought.
por
Adicionar um comentário
1 resposta
It looks like the displays both use the 30-pin system so I am going to assume that a 111 screen would work in a 131. I would be surprised if not.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Camilo A. Gaviria será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 126
