Ir para o conteúdo principal
The Kitchen Gourmet XQ-673H is a 4-cup switch coffee maker made by the Kitchen Gourmet company.
2 Perguntas Visualizar todos
My pot drips like crazy when I pour the coffee
I use this product all the time. However, when I pour my coffee it pours all over the counter, I usually pour over the sink because of this ….but the pot is already small and i hate the mess not to mention the mess it makes.
Any suggestions? I have tried to pour slow and I have checked it for cracks or chips. None
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Mine does this, too. I finally discovered if I hold that little plastic top part up when pouring the coffee doesn't spill.
por
Adicionar um comentário
2 respostas
Solução escolhida
pajohnson  since it happens when you pour the coffee, I do not believe it has anything to do with a dirty coffee maker. It seems that spillage is a problem with most small coffee pots. The small glass coffee pots most likely have a spout that is to short and angulated.
Esta resposta foi útil?
Pontuação 2
It sounds like it needs a good cleaning. Get some white vinegar mixing 50/50 with distilled water and running it through.
Here’s a good reference How to Clean Your Coffee Maker
Pontuação 0
Adicionar a sua resposta
pajohnson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 250
