location of the bios jumper in my SATELLITE P55W-C5200X
i have a satellite P55W-C5200X and can’t find where the bios jumper is located
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
this does not hold true for laptops build within the last 10years. No longer will passwords be erased by removing any battery. Passwords etc., are now stored in IC’s on the motherboard. No jumper setting, no battery removal will clear this. You can try and contact Toshiba to help you recover the BIOS password. Post some good pictures of your motehrboard with your question. that will allow us to see what you see and we may identify certain things for you Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 956
4 comentários
Do you have any Bios problem and you need to factory reset it??
por Luis Anniel
Yes I tried start holding 0 but nothing I lost the bios password and no way to get into the computer
por papa
So, could you explain the whole problem of your computer.
por Luis Anniel
Are you sure there is a BIOS jumper?
On most computers, if you remove all power, and then you remove the CMOS battery for a few minutes, the power on password will be cleared.
por MrJimPhelps
