Ir para o conteúdo principal
Acer Aspire E11-ES1-111M-C40S is an 11.6" laptop. It was released in 2014.
6 Perguntas Visualizar todos
startup "Please insert the external storage media and press ok
Alt F10 i get your pc needs to be repaired. a required device isnt connected or not working. Error Code; Oxc0000225 said i will needrecovery disk or usb if not contact pc maker
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Need more info:
How does this happened??
Was it working ok and then shuts-down??
Did you install something new (Software or Hardware)???
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Patricia Stisser  this "Please insert the external storage media and press ok” sounds like your computer can no longer access the OS. Could be related to a faulty SSD or corrupted OS. Use a rebootable USB drive and set your boot option to USB. See if then boots up.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Patricia Stisser será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 704
