Ir para o conteúdo principal
A thin, light, corporate looking series of computers by Dell.
Why usb port not giving power?
My device usb port not working even no power .please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This is usually due to a worn / damaged USB port. They would need to be replaced via soldering at a reputable repair shop.
Personally I don’t think it’s worth it for a fairly old laptop.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Power is showing in tester.
por
If that is the case I would check on the main board for any liquid damage or loose solder joints for the pins behind the USB ports on the board.
por
Adicionar a sua resposta
Kashif ali será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 78
