Why usb port not giving power?
My device usb port not working even no power .please help
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
This is usually due to a worn / damaged USB port. They would need to be replaced via soldering at a reputable repair shop.
Personally I don’t think it’s worth it for a fairly old laptop.
Esta resposta foi útil?
Power is showing in tester.
If that is the case I would check on the main board for any liquid damage or loose solder joints for the pins behind the USB ports on the board.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 74
