Lens problem canon sx 50
hi
The lens is set to hit and gives voice ratchets
The lens is set to hit the folded When I turn on the sound
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
hi
MEHDI MAKVANDI it sounds as if you are describing that your lens got hit and now has trouble either extending or retracting. You can try to check some of the ideas on here Check to see if the lens is off center. For more ideas check the answers on here Canon Powershot SX50 HS lens won't retract?
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 122
1 comentário
The lens has a problem set
Hit and gives voice ratchets
por MEHDI MAKVANDI
