Ir para o conteúdo principal
A gaming headset that is compatible with the Xbox One.
How to fix water in microphone
So I was playing Xbox with my friends and just as I was talking to them I decided to drink some Pepsi, just then I started choking and spluttered some Pepsi inside the mic and it just got worse from there. What should I do?
It got inside the little tiny hole and when I’m talking to my friends on Xbox they can’t hear me at all
Esta é uma boa pergunta?
Pontuação 10
5 comentários
I have a elecder i39 and i got water in the little hole and it wont work at all. I have to use the chat for zoom.My mic is attched to the cord and its really annoying.HELP ME PLS!
por
i cant get the mic replaced bc it is part of the cord
por
same i thought a mic would survive coke then it started to buzz alot with a voice changer
por
MY Mick sound problem
por
MY Mick sound problem please solve
por
Adicionar um comentário
3 respostas
Pergunta mais útil
try letting mic dry i suggest air dry or blowing into the hole it help me
Esta resposta foi útil?
Pontuação 3
Gear Up For Future Repairs
Hi,
Your best option is to replace the microphone boom as most probably the microphone will be damaged beyond repair, even if you could get to it to repair it without damaging it.
Pontuação 1
2 comentários:
What if the mic is attatched to the headset?
por
mine is and you would have to cut the cord
por
you can try to hairdry it or blow it out that might help
Pontuação 1
Adicionar a sua resposta
ruairi.moran será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 67
Ao todo: 25,527
