Ir para o conteúdo principal
Why are my beats x not turning on
My beats will flash white 3 times and appear red when on charger indicating they are charging but they won’t turn on please help I’ve tried resetting but it does not work and the guide on reddit was way to complicated
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Beats x on charger ….keeps blinking red to white ……will not turn on
por
Adicionar um comentário
2 respostas
Pergunta mais útil
I would try updating them. It might be a simple software issue. Otherwise it would be that the port is damaged.
Esta resposta foi útil?
Pontuação 1
4 comentários:
I’ll check to see if that works thanks for the help
por
I tried updating them and I know there charging because the light turns on and the firmware update didn’t work
por
Same issue. Apple support says they are defective and wants $80 to replace them since mine are 14 months old. Crappy product and poor support.
por
Mine are still under warranty I got em in December
por
You are a doughnut fool !$$&* you need to use a Samsung charger not an iPhone charger go to auction to get a username which has £200 minutes in the account mohamedrashid00
Pontuação 0
Adicionar a sua resposta
Silentgunner COD será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 18,357
