Ir para o conteúdo principal
No picture, just green light
When I turn on my 40 inch Sony Bravia, the tv clicks and the green light comes on. I don’t have any picture or sound. I’ve been told to shine a light in the dark to see if I can see the picture. I tried it and light just reflects off screen. I can’t see any picture. Any suggestions? Could it still be the inverter board? It was working fine, then one day no picture. No warning signs before it happened.
=== Update (04/10/2018) ==
Here is a picture of the whole back and each board. It is model KDL-40S504. I have a multimeter as well.
Update (04/11/2018)
I tried to see if it was in standby mode. It didn’t work when putting in the combo with the remote. Here is a picture of the T-Con board.
Esta é uma boa pergunta?
Pontuação 6
8 comentários
This happens to mu TV everytime i play the you tube app.
por
I played YouTube off of my Sony tv and now the green light turns on but I get no picture or sound. I know nothing about TVs or how to even take the back off of it. I need help!!!
por
erika.ingerson make and model of your TV?
por
I as playing you tube when this happened to mine as well . I still have not found an answer.
por
About every 3 or 4 uses my Bravia does not turn on, except green light. I can unplug, wait, then replug it and it will work. Tired of working hard to reach up behind tv for power location and going through this.
por
Exibir mais 3 comentários
Adicionar um comentário
4 respostas
Solução escolhida
@joebrown this does not sound like a backlight error from a failed inverter etc. You most likely would have audio with it. Your error sounds like a bad power board since you have neither. Let us know what exact model this is and post some pictures of your boards with your question. You'll need some basic tools and a multimeter to test things later on.
Update (04/10/2018)
@joebrown see if you can put the TV into diagnostics mode:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:
DISPLAY==> Channel 5==> Volume + ==>TV POWER .
The Self Check list displays.
NOTE: This is the same as accessing Service Adjustments.
3. To display the Self Diagnostic list, press +
If this works let us know if it displays any "1" under diagnostic information
I need one more picture of the T-con board. That is the board on top of the TV where the cable from the main board plugs into. There will be a fuse on that and we need you to measure continuity of the fuse and later power to the fuse when you turn the set on. You also want to post some more images of the boards just zoom in a bit more so we can check the components closer.
Update (04/12/2018)
check the fuse for a. continuity. After that check to see what the voltage is on it when you turn your set on. Red probe on either side and Black probe on chassis ground meter in VDC
Esta resposta foi útil?
Pontuação 3
11 comentários:
I tested the T-con board fuse you suggested and it had 25 volts when I powered on the TV. Any suggestions from there?
por
okay so you do have power to the T-con board. Can you check on your power supply connector CN6701 for the proper voltage going to the balancer board?
por
Yes. How do I do that? I checked the C6701 on the power supply board and it has 25 volts as well. I couldn’t find the CN6701.
por
Sorry that was supposed to be C6701. okay so your balancer board gets power as well. Let me try and find out where to check the voltage on that board
por
Thankyou, now up and working 5, +volume, on
por
Exibir mais 6 comentários
Hi friend, i has the same problem and i solve it replacement the EEPROM programes with the last firmware if ur TV model. This problem ( green led on bucle) its cause for a corrupt memory.
Pontuação 0
2 comentários:
That did not work.
por
Hello, how do you reprogram it? I updated my tv and it is stuck on green indicator light and Sony logo. Need help please, ty
por
I tried the various suggestions here, but figured it was a bad board. I was done messing with it. It would have been about $40 plus shipping on ebay and a new tv for $99 on black Friday… recycled it.
Pontuação 0
Mine is less than a year old.. I have done steps 1 and 2 and the self check list flashes and then it’s back to black. So can you confirm there is nothing left but a service call for someone with no knowledge of electronics?
Pontuação 0
Adicionar a sua resposta
Joe Brown será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 156
Ao todo: 86,878
