Ir para o conteúdo principal
The Tiida(Versa) hatchback and the Tiida Latio sedan debuted in 2004 in Japan, and in select European countries in 2007.
11 Perguntas Visualizar todos
Will Not Accelerate Replaced Solenoid
My Nissan Versa 2009 will not accelerate . The solenoid was replaced got it from the dealership. By mechanic the car was reprogrammed and worked for a little with slow acceleration then seemed to correct itself the more I drove. Parked it for two hours then went to drive it again and it would not work again. What can be wrong with my car ):
Esta é uma boa pergunta?
Pontuação 0
2 comentários
@reinavia what solenoid was replaced? Have you had your Nissan scanned? Did the OBD display any codes?
por
Yes a bunch of codes were displayed . The mech ordered a whole solenoid pack from the dealer.
por
Adicionar um comentário
2 respostas
Solução escolhida
There are at least 40 Technical Service Bulletins TSB's for your year model. At least 3 of those are for your transmission. Seems to be that this car is a lemon.
But they relate to the reasons why your car doesn't accelerate.
Many TSB's
Esta resposta foi útil?
Pontuação 2
There might be issues with the car that remains unresolved by the previous owner. It would be a good thing if you can decode the VIN and see what you can find about its vehicle history. Might help you identify the root cause and address it.
Pontuação 0
Adicionar a sua resposta
Olivia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 16
Duração total: 1,636
