Ir para o conteúdo principal
Will Not Accelerate Replaced Solenoid
My Nissan Versa 2009 will not accelerate . The solenoid was replaced got it from the dealership. By mechanic the car was reprogrammed and worked for a little with slow acceleration then seemed to correct itself the more I drove. Parked it for two hours then went to drive it again and it would not work again. What can be wrong with my car ):
Esta é uma boa pergunta?
Pontuação 0
2 comentários
@reinavia what solenoid was replaced? Have you had your Nissan scanned? Did the OBD display any codes?
por
Yes a bunch of codes were displayed . The mech ordered a whole solenoid pack from the dealer.
por
Adicionar um comentário
2 respostas
Solução escolhida
There are at least 40 Technical Service Bulletins TSB's for your year model. At least 3 of those are for your transmission. Seems to be that this car is a lemon.
But they relate to the reasons why your car doesn't accelerate.
Many TSB's
Esta resposta foi útil?
Pontuação 2
There might be issues with the car that remains unresolved by the previous owner. It would be a good thing if you can decode the VIN and see what you can find about its vehicle history. Might help you identify the root cause and address it.
Pontuação 0
Adicionar a sua resposta
Olivia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 1,952
