My pilot will not turn on or charge up
My hipstreet pilot will not charge or turn on, can anybody help please?
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
I had the same problem with my hipstreet pilot tablet.
Try using some compressed air to blow out any debris from the charging port.
If you don't succeed try getting a paper clip and bend it so its straight, the get a torch and put the paper clip in, move it around and pull up.
I used both and then charged it and it worked.
Sorry I can't help for the won't turn on.
Esta resposta foi útil?
Try opening it and adding a bit of solder to the charging port
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 555
