Ir para o conteúdo principal
Repair guides and support for tablets made by Hipstreet. These tablets run on the Android OS.
71 Perguntas Visualizar todos
My pilot will not turn on or charge up
My hipstreet pilot will not charge or turn on, can anybody help please?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
I had the same problem with my hipstreet pilot tablet.
Try using some compressed air to blow out any debris from the charging port.
If you don't succeed try getting a paper clip and bend it so its straight, the get a torch and put the paper clip in, move it around and pull up.
I used both and then charged it and it worked.
Sorry I can't help for the won't turn on.
Esta resposta foi útil?
Pontuação 0
Try opening it and adding a bit of solder to the charging port
Pontuação 0
Adicionar a sua resposta
nadrad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 506
