Ir para o conteúdo principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Why isn’t my phone turning on?
i didn’t do anything i just turned my phone off and then after when i tried to turn it back on it stayed off and when i put my charger in it doesn’t say it’s charging. i haven’t dropped it or anything. what should i do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Remove Battery and then plug into charging cable. Try and power up. If this works the Battery is dead and needs to be replaced.
Esta resposta foi útil?
Pontuação 0
unfortunately the phone will not power on without a battery in. Try replacing the battery. If that does not work you most likely have a logic board problem, which is common over time with a phone that old.
Pontuação 0
Adicionar a sua resposta
urie diculous será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 90
