Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
Why does my gameboy not charge?
I have a gameboy that when plugged in the red light flickers and turns off. I have replaced the battery and have also bridged the f1 and f2 fuses but no luck. When battery has charge it works perfectly but does not charge. I just want to know what else causes this problem.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hi!
Have you tried using another charging cable? Maybe the one you are using is old and can't provide enough power to the console?
Esta resposta foi útil?
Pontuação 0
1 comentário:
The charger works on my other gameboy.
por
Get a new charger for it.
Pontuação 0
2 comentários:
The charger works on my other gameboy so i dont think its the charge.
por
You can also get the charging panel replaced at a service center.
por
Adicionar a sua resposta
GH05T R34P3R será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 551
