Ir para o conteúdo principal
The HP Envy Touchsmart m6-k125dx can be identified by its model number: CND40629N2. It's a lightweight touchscreen sleekbook laptop that was released in February 2014. It has a solid build with a full HD display and other useful features for daily computing at a medium level price.
How can I replace front panel
I have a broken front panel Hinge bracket and needs to be replaced completely, please help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link to the service manual for your laptop.
Scroll to p.63 to view the necessary pre-requisite steps and then the procedure to remove the touchscreen display so that the hinge brackets can be accessed.
Scroll to p.21 Item #3 to view the part number for the hinge bracket for a touchscreen model laptop (725449-001).
If you search online using the part number only in the search box, you will get results for suppliers of the part.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Joison Fernandes (Joyson) será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 141
