Ir para o conteúdo principal
Apple iPad da primeira geração, disponível nas versões Wi-Fi e 3G com 16, 32 ou 64 GB de armazenamento.
Screen does not light up
I have a 1st gen ipad a friend gave me it works fine but the lcd does not light up and I'm not sure if it's the lcd itself or the logicboard how can I find out which one is it and how much will it cost to fix. Thanks
Craig
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
hayu2 unless you have the schematic, good multimeter and the ability to microsolder small components, I'd go with the LCD. There is a much greater likelihood that it is the LCD that is just not showing anything. For that repair check which iPad you have on here iPad 1 and then browse the guides. Replacement cost for that is ~$60USD depending on where you check.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
hayu2 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 56
