Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
Should I install a backlight in a gameboy advance sp?
I have a Gameboy Advance SP of the model AGS 001, but want a better screen. Should I attempt to do this? Does replacing the ribbon have any other effects? Should I just buy a new Gameboy Advance SP that has a brighter screen?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Is the screen too dim, I would not recommend to get new one or to get the display replaced
Esta resposta foi útil?
Pontuação 1
2 comentários:
I am considering modding my GBA instead.
por
oh then its fine
you can do it if you are fine with it
por
Pergunta mais útil
The ribbon connectors are different between the two models, if you want to replace the screen, you're going to have to get a pesky adapter that is really hard to fit into the shell. I recommend just getting the 101 model, it's a lot easier and if you find the right place you can get it for under $40. Hope this was helpful.
Pontuação 2
Adicionar a sua resposta
Asta Ulrikke Haugnes será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,821
