Ir para o conteúdo principal
The Dell Latitude E6410 is a 14" laptop released by Dell.
Forgotten entry password locked out
Can't get past the initial locked screen where you put in a password to open & log on.
It's a laptop I haven't used in awhile & I've forgotten my password.
Anyone know a safe way to get into a Dell Latitude e6410 w/o the password??
Update (10/23/2017)
Thought it sounded good so said "YES!" before I called.
When I called they said it would be approx$150.00
IF I wanted to try & keep what might be on it
and approx $100 if they just wiped it out & started over!
plus now they have my info & serial number etc
CRAZY! no way = so if anyone one else has a better idea
on how to be able to get past the password sign-in page
PLEASE let me know ok!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
forgot my password and Im locked out of my dell lap top
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@mamala since this is a system password all you have to do is contact Dell Technical Support at (800)624-9896. Once it is established that you are the rightful owner of this machine, they will provide you with a password. If you are not the original Latitude owner, they will transfer the registration from the original owner to you.
Esta resposta foi útil?
Pontuação 3
1 comentário:
If its not in warranty they want to charge at Dell instead of telling you how to bypass it....horrible company... Dont buy Dell.
por
Adicionar a sua resposta
Linda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 1,139
