Ir para o conteúdo principal
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 Perguntas Visualizar todos
How can I replacing coin cell?
I need replacing coin cell. I started it by instructions of manual. I was disturbed because by instructions I need remove all hardware. By instructions it's not too heavy. Now I see it's very heavy. May be I misunderstood something and there is a much more easier way?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@ibolya that is correct. This is due to the location of the battery. Sorry but there is no easier way.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks! So I must go to the serviz
por
@ibolya either that or use the manual to do it yourself. The manual is descriptive enough so you could do it.
por
Adicionar a sua resposta
Goldner Ibolya será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 114
