Ir para o conteúdo principal
The GoPro Hero3+ Silver Edition (model no. CHDHN-302) was released in October 2013. This digital camcorder is capable of recording 1080p HD resolution video and taking 8MP pictures.
17 Perguntas Visualizar todos
Date Time resetting, can I change just the motherboard battery?
My GoPro no longer seems to be holding date/time.
I'm assuming this is due to the motherboard battery?
If so, is that replaceable? If so, what type of battery and are there online instructions?
I've seen the Hero 3 tear down page, so I know it has a soldered on motherboard battery but even that teardown does not remove/call out the onboard battery type and removal/replacement.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Peter Yamamoto you are absolutely right and there is not a lot of information about this battery anywhere. I just checked mine and it is a 3V MS614FE battery manufactured by Seiko. Here is the datasheet DATASHEET SEARCH SITE | WWW.ALLDATASHEET.COM and most likely Mouser.com or Digikey.com will have those.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Peter Yamamoto será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 229
