Ir para o conteúdo principal
Repair guides and support for battery-powered toothbrushes.
Why is brush vibrating at different rate
Our electric toothbrush is working, but my husband seems to think it is vibrating at a different rate, I.e. faster and less strong. Have you come across this before and can it be repaired?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thanks for the advice. I'll hold out a bit longer. Margaret
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@mcarey this will be difficult since it is based on subjective data. There is really no reason how this could happen. the motor is a direct drive so there is no gearing etc. It either works or does not. Now it is of course possible that the motor is failing, but that would most likely make it run slower. At this time I would suggest you wait and see what happens.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
margaret carey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 117
