lost button on side, is it repairable?
The little button on the side of my charge has fallen off so I can't access the time, steps etc. Is this repairable
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
freakyc, Replacemnt vid. link and possible replacement part below. You can also contact fitbit especially if under warranty or not, as a lot of people have had the same fault and they may value you as a customer and make things right(fit bit support last link). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.ebay.com/itm/2x-Fitbit-Charge...
Esta resposta foi útil?
The device is out of warranty I assume, but there are replacement guides online. However, I was unable to find a replacement part. Sorry I couldn't help more. Good luck!
What replacement guide? Maybe a link will help
Here you go: www.youtube.com/watch?v=udpcDpAqPQU. It isn't the best guide but it works...
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 1,561
