Ir para o conteúdo principal
Fitness and sleep tracking band that also displays caller ID information when paired with a smartphone app. Released in November 2014.
lost button on side, is it repairable?
The little button on the side of my charge has fallen off so I can't access the time, steps etc. Is this repairable
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
freakyc, Replacemnt vid. link and possible replacement part below. You can also contact fitbit especially if under warranty or not, as a lot of people have had the same fault and they may value you as a customer and make things right(fit bit support last link). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.ebay.com/itm/2x-Fitbit-Charge...
https://www.youtube.com/watch?v=t5aMuvxY...
http://help.fitbit.com/?l=en_US&cu=1&fs=...
Esta resposta foi útil?
Pontuação 4
The device is out of warranty I assume, but there are replacement guides online. However, I was unable to find a replacement part. Sorry I couldn't help more. Good luck!
Pontuação 1
2 comentários:
What replacement guide? Maybe a link will help
por
Here you go: www.youtube.com/watch?v=udpcDpAqPQU. It isn't the best guide but it works...
por
Adicionar a sua resposta
freakyc será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 1,712
