Ir para o conteúdo principal
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
iBook beeps and flashes when turned on
My iBook has just become the latest computer to die on me, and now i'm reduced to writing this from a phone's browser.
(iFixit works well on a phone)
I was typing in pages '06 when the screen froze and the keyboard and trackpad stopped working. i held the power button to turn it off and now when i try to turn it on i always get 3 beeps and after that the sleep light flashes 4 times every few seconds. it doesn't give me the chance to try fsck -fy or hold c with a hardware test disc. do i need to reimage?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
Referring to Apple's Knowledge Base (http://support.apple.com/kb/HT1547), 3 audio beeps followed by a repeating pattern of 4 flashes indicates "no good banks" of RAM detected.
If you have added RAM in the expansion slot under the airport card, try removing it and booting without it installed. See this ifixit article: iBook G4 12" 1.33 GHz RAM Replacement for location.
If you get the same error without additional RAM, then the RAM soldered to the logic board has failed, and a logic board repair/replacement will be required.
Esta resposta foi útil?
Pontuação 8
1 comentário:
Thanks to David for a really good answer! Problem solved for us!
por
Related Parts and Tools
this means that there are no good banks (ie ram/memory)
Pontuação 0
Adicionar a sua resposta
QEII Student IT será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 4,490
