Ir para o conteúdo principal
Beats Solo 2 Wireless headphones are a wireless version of the Beats Solo 2. Released in 2014. Model number: MHNG2AM/A.
Headphones will charge, but they will not make a sound?
My headphones I've had for a year have never had any issues, never dropped them or had them around water. I'm not sure what happened, and my warranty expired. Does anybody know what I can do to fix them???
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
Have you ensured that they are still paired with your audio source?
Have you tried pairing it again with either the same or a different audio source?
Have you proved that the audio source is working correctly?
What have you tried to do to make it work?
por
Adicionar um comentário
1 resposta
Hi there,
Have you tried to plug them in to an audio source using the aux cable? (the aux in on the headphones uses the same traces as if the bluetooth mode would.
If that works try to use the beats updater http://your.beatsbydre.com/ and try to do a firmware update /reset
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Virginia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 137
