Ir para o conteúdo principal
Released in 2008, the Canon Speedlite 580EX II featured a built-in PC terminal as well as other upgrades from the 580EX.
2 Perguntas Visualizar todos
Replace battery door cover
Hello - I cannot seem to find any instructions online for how to replace the battery door cover for my Canon 580exii. I had batteries corrode and ruin the receptors on the cover. I have a new cover but I'm not sure how to access the pin to release the old cover. Do I need to open the entire unit up?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link to the relevant section in the service manual for your Canon 580EXII.
It shows an exploded view of the the Battery case Assembly - Disassembly.
On the next page (click the next link page on the bottom of the page) it has illustrations which may help you.
https://www.manualslib.com/manual/379083...
Esta resposta foi útil?
Pontuação 2
3 comentários:
Hi Jayeff - thanks so much for your help. Would you say that indicates I have to take the whole thing apart to get to that pin? Maybe that's best left to the pros. Not sure I want to open it. Not to mention the screws are taunting me with stripping.
por
Hi @scamp ,
Not being able to actually see the camera it is a bit difficult to work it out from the manual as to what has to be done.
There's an old saying that applies in this instance - If in doubt, don't!
por
Ha! Good one and one that I am feeling this time. Thanks!
por
Adicionar a sua resposta
Sara campbell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 2,338
