Ir para o conteúdo principal
Was first released in March 2004, has a 10.4" screen, 64 MB RAM, and 6.4 GB HDD. This device also runs on operating system Windows 95
3 Perguntas Visualizar todos
Why am I having problems with my laptop overheating?
Why does my laptop become extremely hot while in use?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Your laptop may not have enough adequate contact between the heat sink and main processor. This is usually caused by a lack of thermal paste, or that there is air stuck in between the two components. To fix this problem, completely clean off any of the old thermal paste, then apply a bead of new thermal paste directly in the center of the processor. Finally, gently push the heat sink back in place and tighten screws in order to lock down the heat sink.
Another common problem regarding overheating in laptops is usually that there is excessive dust and/or other materials stuck in the vents or fan. To fix this, use a can of compressed air to carefully blow any dust or materials off of the vents and fan.
Finally, if you do not hear the fan running during use then it is likely that the fan may be broken or defective. In this case you will have to replace the fan within the laptop.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ashley Furtado será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 106
