Ir para o conteúdo principal
Dell Latitude D630 is a thin and lightweight version of the Latitude line. With a 14.1 LCD screen and a 9 cell battery, this laptop is meant to be more mobile.
20 Perguntas Visualizar todos
Restart Dell latitude d630c
How do I restart it and why is the orange light blinking
Esta é uma boa pergunta?
Pontuação 0
1 comentário
This question was migrated from http://meta.ifixit.com/Answers.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
A blinking orange battery light indicates a failing or discharged battery.
What indications do you get when you connect the charger?
Is the light continuous or flashing?
If it is continuous allow the battery to fully charge and then try switching it on.
If it is still flashing, remove the battery from the laptop and then connect the charger and see if it will start.
If it does, then perhaps your battery is failing and needs to be replaced. Even rechargeable batteries have a life span.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rick Farley será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 52
