Ir para o conteúdo principal
The Sony Cyber-shot DSC-HX9V is a compact digital camera with a 16.2 megapixel resolution. The dimensions are 4.1"x2.3"x1.3" (WxHxD).
11 Perguntas Visualizar todos
Why is my SD card not inserting?
SD card on Sony Cyber-Shot DSC HX9V will not fully insert into the SD card slot.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
sony cyber shot dsc-w800 memory card not working in the camera slot when turned on! no image on the screen until I remove the sd card / the card was formatted in the camera ok!
por
Adicionar um comentário
1 resposta
Solução escolhida
Hey there Deepjot! Sorry to hear that you are running into this issue. One possible issue you could be having is there is debris stuck in the SD slot. If this is the case use a hairpin and attempt to dislodge the debris from the slot.
For more troubleshooting visit this page:
Sony Cyber-shot DSC-HX9V Troubleshooting
Esta resposta foi útil?
Pontuação 2
1 comentário:
Is there any other solution to this problem. II can not get my card to lock in when I insert it?
por
Adicionar a sua resposta
Deepjot será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 1,428
