Why is my SD card not inserting?
SD card on Sony Cyber-Shot DSC HX9V will not fully insert into the SD card slot.
Esta é uma boa pergunta?
Hey there Deepjot! Sorry to hear that you are running into this issue. One possible issue you could be having is there is debris stuck in the SD slot. If this is the case use a hairpin and attempt to dislodge the debris from the slot.
For more troubleshooting visit this page:
Esta resposta foi útil?
Is there any other solution to this problem. II can not get my card to lock in when I insert it?
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 11
Ao todo: 1,635
1 comentário
sony cyber shot dsc-w800 memory card not working in the camera slot when turned on! no image on the screen until I remove the sd card / the card was formatted in the camera ok!
por James Dale
