Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Why does it do this?
I have a 2003 Nissan Altima, when I crank the car up and put it in drive it stars running bad or might go dead. So I crank it back up and put it in first and start off and put it straight to drive it runs fine, doesn't run hot or anything, but if I stop at a stop sign it'll start running bad again and have to repeat the same step, from first straight to drive, any idea what this might be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@hutch6 not sure where you are but I would get the OBD scanned to see if it throws any codes. Sounds like it is coming from the transmission.
Rep: 1
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Shane, This could be caused by a few things. It sounds like your transmission torque converter lock up/solenoid may be malfunctioning/sticking. Take into a good shop, have them scan for trouble codes, diagnose and estimate repair. Good luck.
Pontuação 2
Adicionar a sua resposta
Shane hutcherson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 158
