Ir para o conteúdo principal
Model zd8000, 17" Widescreen display, 2.8-3.6 GHz Intel Pentium 4 processor
8 Perguntas Visualizar todos
OE does not saving sent items
A user is using Outlook Express at home (I don't know why) it is not saving his sent items?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Can this email account send or receive mail at all ?
por
Adicionar um comentário
2 respostas
Solução escolhida
I think you will not get such a tool but you can repair the corrupt DBX files and once you have working DBX files, you can import them into Outlook to merge into a single PST file. According to our experiences, https://onlinefilerepair.com/en/outlooke... has the powerful capability in recovering corrupt .dbx files
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Outlook Express 2Gb limit problem.
How to fix Outlook Express dbx 2Gb limit problem.
Outlook Express stores emails in special files with .DBX extension. Every Outlook Express folder has its own file with DBX extension. For example,Inbox folder has a corresponding Inbox.dbx file, Outbox folder has a corresponding Outbox.dbx file and so on. There is a 2Gb limit for every DBX file and that can cause some serious problems. The matter is that the users often use e-mail nowadays to exchange different files with each other. As a rule, these are documents, photos, music, videos, program files, etc. All these files are of big size and your mailbox can eventually reach the 2Gb limit.
When Outlook Express folder reaches its 2Gb limit you can't place any messages in it anymore
Follow this tutorial on how to fix the problem.
http://www.wintips.org/fix-outlook-expre...
Pontuação 2
3 comentários:
Do you know if this is also true for Outlook for Mac 2011 vers 14.3.7. @oldturkey03 is having to forward pictures to me from @jayeff of his vacation because they bounce on me. Could this be my ISP? I use Suddenlink.
por
There isn't a 2 gig limit with Outlook. I will have to research to see if there is a limit.
por
Thank you guys for your feedback and help. Sorry, that long time did not respond. This is because the issue was solved and I forgot to tell.) Thank you!
por
Adicionar a sua resposta
JoshuaAlexander será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 72
Últimos 30 dias: 223
Duração total: 3,079
