Ir para o conteúdo principal
Repair and disassembly guides for garage door openers.
18 Perguntas Visualizar todos
Jerking upon opening garage initially
Lately, when I go to open my garage door, it jerks and then stops. I have to then close it and start again to open it. What could cause it to do this?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@mactechplus thought you might have some advice on this one.
por
Adicionar um comentário
3 respostas
Solução escolhida
The rollers on the side are binding in the tracks. Track bent? Roller bent?
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks, will have to check if they are bent.
por
Check the rollers on each side, make sure the are not crooked, binding, or other wise. Often the tracks that they run in can get a little tweeted, and this can cause issues, especially where the two pieces meet. Could be binding there.
Pontuação 0
If your door still has a manual lock on it, sometimes the bar can catch on the track as it passes through the curve.
Pontuação 0
Adicionar a sua resposta
Wendy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 4,296
