Jerking upon opening garage initially
Lately, when I go to open my garage door, it jerks and then stops. I have to then close it and start again to open it. What could cause it to do this?
Esta é uma boa pergunta?
The rollers on the side are binding in the tracks. Track bent? Roller bent?
Esta resposta foi útil?
Thanks, will have to check if they are bent.
Check the rollers on each side, make sure the are not crooked, binding, or other wise. Often the tracks that they run in can get a little tweeted, and this can cause issues, especially where the two pieces meet. Could be binding there.
If your door still has a manual lock on it, sometimes the bar can catch on the track as it passes through the curve.
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 4,199
1 comentário
@mactechplus thought you might have some advice on this one.
por mayer
