Ir para o conteúdo principal
The Lenovo ThinkPad E540 was released in August 2014. It can be identified by its model number: PF-01G2R9.
9 Perguntas Visualizar todos
How do I switch on WIFI and bluetooth
how do i switch on the wifi
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Have you tried using the FN8 key? Some people have issues getting the FN keys to work- you can try downloading the Power Management Driver from Lenovo's website, which will allow you to access all of the FN keys on your keyboard.
If you don't want the Lenovo display popping up every time you use it, you can simply install the driver, turn on wifi, and then uninstall it. Hope this helps.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mahube será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,104
