Ir para o conteúdo principal
Released in 2015, the all-in-one camera featuring WiFi, Bluetooth, touch screen display, and waterproof capabilities.
Why touch display not going on
I put my gopro hero+'s touch display off and the screen went off and cant seemntobget it on again! Have to use the small screen in the front now but it does not give me option to put touch display back on! Please help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is an image taken from the Gopro Hero + LCD user guide which shows that if you navigate with the Power/Mode button to the Set Up mode icon, you should be able to access the Touch Display icon, select it and then presumably turn it on or off.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
juanversfeld será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 20
Ao todo: 355
