Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Adding a 2nd SSD. Are cables included?
Has anyone tried to add a 2nd SSD when the iMac originally has a built-in (non-removable) SSD? I'd like to find out before opening her up, since the new display glass are not magnetic like in older models.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
First the Apple blade SSD is removable, its just very difficult to get to. Review this IFIXIT guide: iMac Intel 27" Retina 5K Display SSD Replacement.
As to swapping out your current HD for a second SSD, yes that is something you can do. You will have a few issues here. First thing is replacing the HD's thermal sensor, while the replacement SSD doesn't get as hot as a HD you still need to add-in a replacement thermal sensor like this one: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later. In addition you'll need an adapter frame to mount the 2.5" SSD into the 3.5" HD frame. Here's what I recommend: OWC 2.5" to 3.5" Drive Adapter Bracket. Here is the IFIXIT guide you'll need to follow: iMac Intel 27" Retina 5K Display Hard Drive Replacement.
I must warn you, you can damage the display assembly if you don't use the correct tools and techniques as written in the IFIXIT guide. This could be a very expensive upgrade if you need to then need to replace the display! Last thing here is make sure you have broken the Fusion Drive set before you replace the HD otherwise you can encounter problems.
You may want to think about using an external Thunderbolt2 RAID drive setup. Depending on what you are looking for you might find this a cheaper and safer upgrade. Here's one unit: OWC ThunderBay 4 mini. We have a few of these and find them quite effective.
Imagem de iMac Intel 27" Retina 5K Display Disco rígido
Guia
Substituição do disco rígido do iMac Intel 27" com tela Retina 5K
Nível de dificuldade:
Moderado
1 - 2 hours
Imagem de iMac Intel 27" Retina 5K Display Blade SSD
Guia
iMac Intel 27" Retina 5K Display Blade SSD Replacement
Difícil
2 hours
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Johnny H será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,025
