Ir para o conteúdo principal
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
20 Perguntas Visualizar todos
My tablet will not come on.
, my tablet will not come on at all I don't know what is wrong. Help
Esta é uma boa pergunta?
Pontuação 24
32 comentários
I have tried to reboot holding the power button and the +volume simultaneously and I have scrolled down to do a factory reset. I went through this several times and it still comes up to the Nextbook screen and nothing more. I tried to plug it into my home PC and it didn't work either.
por
I have the nextbook ares 11 and it won't come on I tried to hold power and volume down and it still won't come on PLZ HELP
por
i have the nextbook 8 and every time i power it on it shows up your device has failed verification and may not work properly PLZ HELP ME
por
i tried to fix my tablet but it won't work plz help me.
by nargis Ali
por
I am having the same problem but when I plug in my charging cord to charge it the light flashes red what could it be. I need help need it for my business.
por
Exibir mais 27 comentários
Adicionar um comentário
3 respostas
Solução escolhida
Is it possible the tablet is not charging and you are dealing with a dead battery. when you plug it in to the charger does it show any lights or display on the screen . if not you may need a new charge cable or a complete charger. If its charging properly then try holding the power button down till you get some sort of response. if that doesn't work try holding the power button and the volume down button till you get the android logo then navigate down in the menu to boot normally and select that.
Esta resposta foi útil?
Pontuação 16
18 comentários:
Thank you ... This worked also on my brand new next book 10a
por
I have tried all of the above and nothing happend. This tablet is not three months old started acting slow then just stopped aftet a few weeks from purchasing. It was purchased for my daughter.
por
I have tried it all will not come on.
por
thank you this fixed my tablet
por
How long do you have to hold them?
por
Exibir mais 13 comentários
Hello,
This just happened to my Nextbook. This worked for me like a charm.
1. You have to take the back cover off first.
2. Look for the power connector (it's white leading from the battery).
3. You have to carefully disconnect the power connector from the tablet for 25 seconds.
4. connect it back like it was . i was able to power it up with not problem .
I would probably charge the battery before attempting , it may not make a difference .
the back cover is pretty easy to take off.
feel free to drop me an email if you wish ... malcolm.powell@mycomputerbackups.com
Pontuação 8
18 comentários:
Thank you so very much MCB! My tablet hasn't worked in over a year and I was about to get rid of it when I decided to give one last shot to troubleshooting. Your description helped so much and it turned out that the battery connector had come slightly loose which when plugged in caused the nextbook logo to flash on and off.
por
Glad, we were able to assist you .
por
My Nextbook tablet will not come on for nothing and I don't know what to do I tried holding down the power button and the volume button but it won't work and my tablet has not been working for two years please help me !!
por
What model of tablet do you have ?
por
how do you take the back off
por
my answer is buy a new tablet
Pontuação 0
Adicionar a sua resposta
Famous Shawty será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 55,423
