Ir para o conteúdo principal
A 1.9 GHz DECT 6.0 multiple channel handset capable cordless phone, VTech CS6719-2.
Why do I not get a dial tone?
When I go to make a call there is no dial tone?
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Hi,
Have you got a non wireless type (wired or corded) phone that you can plug into the telephone line socket to see if you get dial tone ? Does your phone show that the battery is charged? What happens when you call your phone number, using another phone?
por
Hi Jayeff,
Thanks for your quick comment. I am actually doing this ifixit project for a course in college and they require us to ask three common problems with the phone. So we don't actually have this problem but it is a very common and one of the other members of my group answers the question. Thanks for helping though.
Josh
por
Adicionar um comentário
2 respostas
One of the things i would check would be on the menu screen on the phone you can adjust the volume.
Esta resposta foi útil?
Pontuação 0
Related Parts and Tools
I frequently find one of my Vtech handset unable to make connection with the base station. I would love to find a way to solve that problem permanently. I can only temporarily correct the issue by disconnecting and reconnecting the battery. This is annoying and will eventually result in the destruction of the small connector which is not designed for frequent disconnection.
Jean-Michel Paris
jmparismail@gmail.com
Pontuação 0
Adicionar a sua resposta
Josh Showalter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 6,245
