Ir para o conteúdo principal
No Picture -- Just a Red Blinking Light
My 10-year-old 40" Sony Bravia has no picture but the standby light is blinking 3 times. It was repaired a few months ago by replacing the motherboard.
Now it's happening again. Is it worth repairing or should we just chalk it up to planned obsolescence and replace the TV?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
@auntiemoses since you did not give us the exact model number, we can only give you a generic Sony Bravia error code. 3 Blinking lights is usually caused by a bad main logic or power board. You would have to check for the standby voltage and see if those are okay. If they are then your error is most likely related to the main logic board. It could be as simple as a couple of bad caps on the board. If you tell us the exact model number we can probably get more information for you.
"Is it worth repairing " depends on your skills. To replace any board is usually only a fraction of the cost for a new TV, so I'd say go for it. Unplug your set, remove the back and post some images of what your boards look like with your question. For that, use this guide
Esta resposta foi útil?
Pontuação 1
10 years is a good life span
to answer you question
it all depends on repair cost
weather you can afford to replace
The way i personally look at it is if the repair will cost more than 30-40% of a new tv then replace
so for example
a new standard 40 inch tv in the uk is around £200
so if the repair costs anywhere from £60-80 replace tv
or repair cost of £40 i would repair
but seen as this has happened to you once already i would suggest a replacement
Pontuação 0
Adicionar a sua resposta
Mary Myers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,553
