Ir para o conteúdo principal
Repair guides and support for the first generation Grand Cherokee ZJ, an upscale mid-size SUV built by Chrysler's Jeep division.
How do I wire a tachometer
how do i wire a tachometer on a 1993 jeep grand cherokee
Esta é uma boa pergunta?
Pontuação 0
1 comentário
what make and model is your Tach? Post some images of the connectors with your question. Use this guide Adicionar imagens a uma pergunta já existente for that
por
Adicionar um comentário
1 resposta
Solução escolhida
jimmiller1940, as a general answer since we do not know which tach you have, most aftermarket tachometers only have 3 or 4 wires that need to be connected. Usually a green wire for the tach, red for power, black for ground, and white or yellow for the back light. The power wire that gets connected to a 12 volt ignition source, the tach signal wire that connects to the coil or the designated signal wire in your cars wiring diagram.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
jimmiller1940 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 1,049
