Ir para o conteúdo principal
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
How to recover Internal Storage (Unit split in to two)
Hello,
My Zenfone 2 ZE550ML was split into two, is there a way to retrieve the internal storage of the unit? Does anyone knows where it is located?
The unit was severely destroyed however I am quite sure that the camera and other parts are still good.
Thanks in advance!
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Any updates? Have you tried taking the phone apart?
por
I believe the motherboard is still fine.
Are there any other tool needed for me to connect the motherboard to my PC?
Appreciate your help. ;)
por
Adicionar um comentário
2 respostas
Solução escolhida
The only way you will be able to retrieve your data is to move the mother board into another identical phone or repair the one you have enough to connect it to a computer and retrieve your data that way. if the mother board is damaged to bad then all is lost
Esta resposta foi útil?
Pontuação 3
2 comentários:
it's possible connect to pc (cable usb?) the memory into the motherboard ?
por
only if you can power the original motherboard which is basically fixing the phone
por
Well, if it split into to and missed the motherboard(only in the upper portion of the phone) then getting a donor phone would be a good way of retrieving data.
Can you upload images of the phone?
Pontuação 2
Adicionar a sua resposta
Jr Chupungco será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 262
