lens error restart camera
Camera, lens error restart camera
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Robert Royer, sounds like a stuck lens. That would give you that error. Check on here for some generic instructions. It is also possible that the DC-DC converter board has failed. There is a fuse on the board that you can check to see if it has continuity.
If you have a multimeter we can also check some of the other components. If you don't than the only fix for that is most likely a replacement of the board and/or a lens replacement depending on your findings.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 15
Ao todo: 3,220
2 comentários
I really would love this camera to be fixed...thank you
por mia manners
@mia manners what have you checked? Have you looked at the answer and tried it out? What did you find? What is going on with your camera? Give us more details than a one liner :-)
por oldturkey03
