Ir para o conteúdo principal
The Garmin Vivoactive is a GPS smartwatch that includes sports apps for tracking activities, notifications, calories, and sleep. This watch incorporates features for both active and working environments.
20 Perguntas Visualizar todos
Why isn’t the touchscreen working?
The screen freezes and becomes unresponsive to the touch.
Esta é uma boa pergunta?
Pontuação 8
7 comentários
this is the solve problem
هذا هو حل المشكلة
قم بتحميل هذا الروم للمطور الرائع mugurete
https://drive.google.com/open?id=0B_hRh3...
por
I flash this to my smart watch but touchscreen isn't working.
por
I left mine on the radiator for 5 min and seems to be working... for now.
por
It's not working because it's a $25.99 watch mine broke 2 days after I bought it.
por
Chris Allen, your answer is really helpful. thank you very much for your insight and wisdom.
por
Exibir mais 2 comentários
Adicionar um comentário
6 respostas
Solução escolhida
This could be a simple problem with a simple fix. First make sure the device is clean and free of dirt and dust. This is the most likely reason the touchscreen isn’t functioning properly. If the device is clean and still is unresponsive, perform a touchscreen-free factory reset of the device detailed in the troubleshooting guide. If a factory reset is unsuccessful, the screen may need to be replaced. Visit this Troubleshooting Page for help with the above and more answers.
Esta resposta foi útil?
Pontuação 6
3 comentários:
Just opened mine and none of the touch screen works
por
My watch screen turn white , so i dont know how to fix it
por
just opened mien and screen wont even work
por
will a factory re-set remove all of the data I've already recorded?
Pontuação 1
3 comentários:
It honestly hurts how painfully stupid your comment is.
por
Be fair - sometimes a "factory reset" may not be all it seems. That has become a well-worn term that sometimes means what it says, and sometimes is a bit of a reboot flushing some - but not all - data. It depends on the device and what exactly the "reset" does.
por
If you force the watch off by holding the power button, it does not erase any data. If you hold the right button while powering it back on it will.
por
3 day old vivoactive hr touchscreen not working?
Pontuação 1
2 comentários:
The vivoactive HR is different than the vivoactive. If the touch screen stops working on it and there is no damage to the display, it is most likely a calibration issue. Just reboot the watch by holding the left button 20 to 30 seconds or till the screen goes black. Then release the button and hold it for a second or two to turn it back on. When the watch turns back on it displays Garmin and calibrates the screen. Do not touch it while it says Garmin.
por
Thank you! This was so frustrating. Reset worked! Garmin did not show though.
por
Just got mine and the touch screen stopped working
Pontuação 1
I bought an hour before 3 months. After swimming in the pool right button for more options does not work, while the left buttom and touchscreen work. What should I do?
Pontuação 0
1 comentário:
I have the same problem, could you fix it?
por
from where can i get the spare touch screen for my broken smartwatch
Pontuação 0
1 comentário:
from where can i get replacement
por
Adicionar a sua resposta
Tessa Gunnin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 31
Últimos 30 dias: 123
Duração total: 131,406
